Applying single legend to multiple layers
по адресу http://gis-lab.info/qa/qgis-multiqml-eng.html
Tool background and description.
This tool can be used for applying a single legend file (qml) for multiple raster or vector layers in QGIS.
Installation notes
Plugin is available via QGIS official repository.
MultiQML is under development and tested with QGIS 1.0.1.
You can obtain sources with this command:
svn co http://svn.gis-lab.info/multiqml multiqml
How does it work
After plugin installation and startup by clicking
main window will appear:
At left there is a layers list which shows layers depending of the active selector «Raster» or «Vector». To apply style to layers:
- select layers in list (press "Select all layers" to select all available layers of the given type)
- if you want to make style default — check "Save as default" checkbox
- press "Apply style" button and select desired .qml
To restore original styles: select layers and press "Restore initial style".
Demo
In this demo, the tool is used to apply a single legend to series of uniformly indexed raster, that have comparable color tables. During demo it is also used to use single min-max legends for series of USGS dems.
<object width="943" height="576">
<param name="movie" value="/images/qgis-multiqml-01.swf"> <embed src="/images/qgis-multiqml-01.swf" width="943" height="576"> </embed>
</object>
Contacts
If you want report a bug or want make suggestion — use bugtracker. Also if you have a question about the script or plugin usage, you can contact us directly.
