  • MOLUSCE is a QGIS plugin for Land Use Change Evaluation. MOLUSCE abbreviation stands for Methods Of Land Use Chande Evaluation. Briefly, the plugin implements the following process:
  1. Takes raster of land use categories for time period A (past), raster of land use categories for the time period B (present) and rasters of explanatory variables or factors.
  2. Trains a model that predicts land use changes from past to present.
  3. Predicts future land use changes using derived model, current state of land use and current factors.
  • State raster is one-band raster where each pixel is assigned with landuse category.
  • Input state raster is one-band raster describing the past.
  • Output state raster is one-band raster describing present. It is the desired result of prediction for model (a user trains the model to predict (input raster, factors) -> output raster).
  • Factor raster is a raster of explanatory variables. The rasters can be one-band or multi-band.
  • Transition class or simple 'transition' is a information about land use change. Every change (for example forest -> non-forest) can be viewed as a transition of land use categories (encoded as pixels) from Input state raster to Output state raster.
  • Change map is a integer one-band raster that stores information about transitions. Category values of change map are mapped one-to-one to transition classes.
  • Utility modules
  • Algorithmic modules:
    • Area Analysis - provides procedures to calculate amount change between states, create change maps
Utility modules
Utility modules are called from other modules of the plugin. The most important utility modules such as DataProvider and Sampler are discussed in this section.
Data Provider
Sampler
Sampling procedure is used Logistic regression and Multilayer perceptron predictors. This procedure collects samples that are used during fitting of the model. But Sampler collects transformed data, because usually the transformation allows achieve better fitting. MOLUSCE uses two transformations:
  • Dummy coding for categorical variables.
Dummy coding
As the initial state raster and change map are categorical, each of them must be transformed to set of independent variables. To do that the plugin uses dummy coding - a categorical variable of N levels is divided into N-1 dummy variables. For example, for 4 classes land use map (Agriculture, Forest, Urban, Water), we have to use 3 dummy variables:
Dummy 1 Dummy 2 Dummy 3
Agriculture 0 0 1
Forest 0 1 0
Urban 1 0 0
Water 0 0 0
Normalization
Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle X_n = \frac{X-m_x}{\sigma_x}}
where X is a variable, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle X_n} is normalized variable, is mean of X and is standard deviation of X.
Description of the sampling process
Sampler works with single pixels and a neighborhood of pixels. This means that a user can take into account a set of pixels around current pixel. The implementation of the algorithm uses Moore neighborhood. For example, if the user sets up 1-size neighborhood then sampling procedure reads the current pixel and all pixels located in immediate vicinity (3x3 window size). If the user set up 2-size neighborhood then sampling procedure reads the current pixel and all pixels located in 5x5 window size and so on. Every neighborhood is stored as vector (9 elements, 25 elements and so on). Sampling is performed for every input raster (initial state raster and factors).
Thus a sample contains:
  • coordinates of the pixel,
  • "All". This mode extracts information for all pixels of the input and output rasters. Among other methods this mode of sampling needs the biggest amount of RAM and CPU time.
  • "Random". This mode extracts information for randomly selected samples: if raster has N pixels, then the every pixel has 1/N probability of being selected.
  • "Stratified". This mode randomly undersamples major categories (large areas) and/or oversamples minor categories (small areas). If C is desired count of samples and K is number of output categories, then the sampling procedure select K random groups of pixels of equal size C/K. Every group will contain pixels of one certain category.
Cross Tabulation
Cross Tabulation is a module that is used in several places of the workflow. The main purpose of the module is to create contingency tables. For example it is used during creating of transition matrix. In this case the method calculates transition statistic -- how many pixels has been changed. The result is the table:
Algorithmic modules
Area Analysis
Category 1 0 1 ... N -1
Category 2 N N + 1 ... 2N -1
Agriculture 0 1 2 3
Forest 4 5 6 7
Urban 8 9 10 11
Water 12 13 14 15
Output of Area Analysis stage is a change map - raster where each pixel is assigned an integer value indicating its transition.
Modeling
A user has a number of factors, init state raster and final state raster. The goal of modeling stage is to create a model that can predict land use changes between those states. Before discussing prediction methods we need to explain common preparation stage.
The next assumptions are currently used by the plugin:
  • For ANN, MCE and LR model factor rasters assumed ordinal or continuous (one-band or multiband), but not categorical.
  2. Sampling.
  3. Training.
MOLUSCE uses multilayer percepron with numpy.tanh sigmoid function. Therefore target variables (the change map categories) should be scaled to (-1, 1) interval during dummy coding instead (0, 1). A user can set arbitrary number of hidden layers (one or more) and arbitrary number (one or more) of neurons in the layers.
The created net has
  • input neurons;
  • output neurons (it depends on samplig mode);
Where C is the count of land use categories, N is the neighborhood size specified by the user, B is the summary band count of factor rasters (for example if two factors are user one-band and three-band, then B=4). M usually is a count of uniques categories in the change map (). But the count of output neurons can be less then M, it depends on the sampling mode. If mode "Random" is used, some small classes could be omitted during sampling procedure.
Training set is divided in two parts: learning set (80% of samples by default) and validation set (20% of samples).
where E is a sample error, is the target value of a output neuron for given sample, is the real output value of the neuron, d is the count of output neurons.
  • Min validation overall error. This is average square error E that is achieved on all validation set (mean of all E on validation set). This is the best currently achieved result. The weights of the net are stored and after training the best weights will be returned as the best net.
Logistic regression
  2. Sampling.
  3. Training.
The created model has coefficients, but only are independent. As before (see perceptron discussion), C is the count of land use categories, N is neighborhood size specified by the user, B is summary band count of factor rasters (for example if two factors are user one-band and three-band, then B=4). M usually is count of uniques categories in the change map (). M depends on the sampling mode also.
  • is an intercept;
  • are the coefficients of dummy variables of current landuse state (categories of the raster are coded as: 1 = (0, 0, 1); 2 = (0, 1, 0); 3 = (1, 0, 0); 4 = (0, 0, 0), see Sampler discussion);
  • Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_4} is the coefficient of factor pixel (0-neighborhood).
  • Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_0} is an intercept;
  • Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1, b_2, b_3} are the coefficients of dummy variables of current landuse state;
  • Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_4} is the coefficient of the first factor (0-neighborhood).
  • Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_5} is the coefficient of the second factor (0-neighborhood).
  • coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{27}} are the coefficients of dummy variables of current landuse state: (Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1} , ..., Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_3} are dummy variables for the upper-left corner of 3x3 neighborhood window);
  • coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{28}} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{36}} are the coefficients of the first raster pixels (1-neighborhood uses 9 pixels or 3x3 window);
  • coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{37}} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{45}} are the coefficients of the second raster pixels.
Weight of evidence
Weight of evidence method was developed to process binary maps, but the method was later modified in order to enable it to handle multiple categories of variables. If user uses rasters with continious values, he has to transform them into categorical variables. MOLUSCE implementation uses the last one modification. To handle continiou factors user must split raster values into several categories (range binning). The GUI has a form that allows to perform transformation into categorical variables. A compromise is needed here: if the user set up too many binning values, then a small amount of pixels might fall into a category and accuracy of statistical calculations will be poor; on contrary if the user set up few bins, which will lead to few of weights are formed, that leads to poor accuracy again.
In the binning form GUI doesn't display all of the used rasters: if a raster is already categorical, it doesn't need transformation and it doesn't appear in the form. Currently a simple procedure is used to decide if rasters as categorical: if a raster has more then MAX_CAT (=100) unique values, then the raster is supposed to be continious, otherwise the raster is treated as categorical.
The WoE fitting procedure starts after the transformation continious -> categorical.The change map is divided into series of binary maps (one map per a transition class), then the set of weights are estimated for every binary map.
Multi criteria evaluation
The goal of the method is to predict a transition class encoded in the change map. Factor rasters are input data, places where a transition occurs are target values. MCE takes pairwaise comparison matrix of factors and calculates weights of every factor. This means, that a user must specify the comparison matrix for every transition class. But count of transition classes increases as Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle O(n^2)} , where n is count of landuse categories (for example if n=4, we have 16 transition classes). To specify all comparison matrices for all transitions is too long and boring, that's why the MCE model predicts one transition class only.
The method needs normalization of factor rasters: this implementation uses a linear combination of factors, therefore they should be transformed to Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle [0, 1]} . The module uses the next transformation:
Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle X = \frac{x - x_{min}}{x_{max}- x_{min}}}
where X is normalized raster value, x is initial raster value, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle x_{min}} is the min value of the raster, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle x_{max}} is the max value of the raster.
Simulation
  • Initial state raster;
  • Factor rasters;
  • Model.
  1. Simulator takes transition probabilities from the transition matrix and calculates count of pixels that has to be changed (for every transition class);
  2. Simulator calls a model, pass to it initial state raster and factor rasters;
  3. The model scans pixels of the rasters (and its neighbors if the model uses neigborhood) and calculates transition potentials of every transition class;
  4. Simulator constructs a 'certancy' raster: the pixel of the raster are the difference between two most large potentials of correspondent pixels of transition potential rasters. As result the raster contains the model confidence: the bigger is difference, the bigger is confidence;
  5. Simulator constructs a raster of the most probable transitions: the pixels of the raster are the transition class with the biggest potential of transition. This raster is an auxiliary raster used during the next stage;
  6. For every transition class Simulator searches in the raster of the most probable transitions a needed count of pixels with the greatest confidence and changes the category of the pixels. If confidence of two or more pixels are close, then random choise of the pixel is used.
  • Rasters of transition potential (scaled to percents) that are output from the models;
  • Raster of the difference between the two most large potentials or 'certancy';
  • Result of simulation.
Validation
  • Kappa statistics;
  • Error budget validation;
  • Error map validation.
Kappa
  1. Kappa:
    Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle K = \frac{P(A)-P(E)}{1-P(E)}}
  2. Kappa location:
    Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle K_{loc} = \frac{P(A) - P(E)}{P_{max}-P(E)}}
  3. Kappa histogram:
    Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle K_{h} = \frac{P_{max} - P(E)}{1-P(E)}}
where Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle P(A) = \sum_{i=1}^c p_{ii}} , Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle P(E) = \sum_{i=1}^c p_{iT}p_{Ti}} , Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle P_{max} = \sum_{i=1}^c min(p_{iT}, p_{Ti})} and Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle p_{ij}} is the i,j-th cell of contingency table, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle p_{iT}} is the sum of all cells in i-th row, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle p_{Tj}} is the sum of all cells in j-th column, c is count of raster categories.
Error budget
  • No location information, no quantity information;
  • No location information, medium quantity information;
  • Medium location information, medium quantity information;
  • Perfect location information, medium quantity information;
  • Perfect location information, perfect quantity information.
Error map
MOLUSCE produces map of errors. This map contains information about false predictions in simulated raster. The error map can be constructed by compassion of simulated map and reference map. The errors of simulation are stored in the error map.
Error map creating procedure has two modifications: two map comparison case and three map comparison case.
Two maps comparison case
This modification compares simulated map and reference map.
Traditional approach to two class (C1 and C2) problem uses tree types of prediction statuses:
Reference Map C1 Reference Map C1
Simulated C1 Hit Misses
Simulated C2 False alarms Hit
In common case (N classes) count of the possible types of errors is rather large, for example if three land use classes are analyzed, then there are 9 possible transition classes and there are three hits in the table:
Reference Map C1 Reference Map C1 Reference Map C3
Simulated C1 Hit Error (type 12) Error (type 13)
Simulated C2 Error (type 21) Hit Error (type 23)
Simulated C3 Error (type 31) Error (type 32) Hit
So in case of N class problem the classification "hits, misses, false alarm" is not so good because the terms "Misses" and "False Alarms" became ambiguous.
MOLUSCE uses common N class approach, when error map contains every transition type error marked by a particular color, "Hits" are transparent. The errors are coded as transitions in change maps (see Area Analysis section).
An example of error map for land use classes "Forest", "Agriculture", "Urban" and "Pasture" is presented on the picture below.
This picture contains location of error pixels. If a transition for a certain location was simulated correctly then the pixel is transparent (white color on the picture). If the transition was simulated incorrect, then the pixel is colored. For example a big cloud of light-green pixels is located on the right side of the error map, the color says that the pixels mark locations of false "Urban to Pasture" transition. This means that in the reference map the pixel has "Urban" meaning but in the simulated map the pixel is "Pasture". A similar interpretation can be done for other colors.
Three map comparison case
This modification uses three rasters for checking: simulated map, reference map and initial map.
The same idea of comparison is used for checking persistent classes and simulation errors. Persistent classes are pixels that are constant in initial raster, reference raster and simulated raster. Such pixels are marked by a certain color, "Hits" are transparent and transition errors are marked as in the two-map comparison problem.
Special topics
Memory Usage
This section contains some examples of the plugin memory usage. The table lists stage of analysis and approximate memory usage (reported by system resource manager). Column Memory shows information about peak memory usage achieved during the stage; later stages can accumulate memory usage from previous stages (for example simulation stage needs data of model stage), but after completing a stage some of unused memory can be released. This process can be viewed in the tables.
The table contains data about tree landuse class task and three one-band factors, the raster sizes are approximately 2000x2500 pixels. In the table ANN has one hidden layer of 10 neurons. The models are trained on 2500 samples, neighborhood is 1.
Stage Peak memory usage (Mb)
Reading rasters 45
Correlation checking 375
Updating transition statistic 355
Creating change map 385
ANN training 500
LR training 450
WoE training (2 range breaks) 1100
Simulation 1200
Error budget validation 1000
Kappa validation 750
Creating error map 700
