- Transition class or simple 'transition' is a information about land use change. Every change (for example forest -> non-forest) can be viewed as a transition of land use categories (encoded as pixels) from Input state raster to Output state raster.
- Change map is a one-band raster that stores information about transitions. Category values of change map are one-to-one mapped to transition classes.
- Utility modules
- Algorithmic modules:
- Area Analysis - provides procedures of change searching, making change maps
Utility modules
Data Provider
Sampler
Sampler works with single pixels and a neighborhood of pixels (it uses Moore neighborhood). This is means that a user can take into account a set of pixels around current pixel. The implementation of the algorithm uses square neighborhood. For example if the user set up 1-size neighborhood then sampling procedure reads the current pixel and all pixels located immediate vicinity (3x3 window size). If the user set up 2-size neighborhood then sampling procedure reads the current pixel and all pixels located in 5x5 window size and so on. Every neighborhood is stored as vector (9 elements, 25 elements and so on). That sampling is performed for every input raster (initial state raster and factors).
Therefore, a sample contains:
- coordinates of the pixel,
- state pixel vector is the neighborhood that is read from 1-band raster, this raster contains initial states (categories). The raster is divided into set of dummy variables before sampling (see below).
- factor pixel vectors are the neighborhoods extracted from factor rasters (they can be multiband).
- "All". This mode allows store all pixels of the input and output rasters. The mode of sampling needs big amount of RAM and CPU time if input rasters are big.
Cross Tabulation
| Category 1 | Count of unchanged pixels of Category 1 | Count of transition Category 1 - > Category 2 | ... | Count of transition Category 1 - > Category N |
| Category 2 | Count of transition Category 2 - > Category 1 | Count of unchanged pixels of Category 2 | ... | Count of transition Category 2 - > Category N |
| Category N | Count of transition Category N - > Category 1 | Count of transition Category N - > Category 2 | ... | Count of unchanged pixels of Category N |
Algorithmic modules
Area Analysis
| Category 2 | N | N + 1 | ... | 2N -1 |
| Category N | (N-1)*N | (N-1)*N + 1 | ... | N*N -1 |
| Agriculture | Forest | Urban | Water | |
| Agriculture | 0 | 1 | 2 | 3 |
| Forest | 4 | 5 | 6 | 7 |
| Urban | 8 | 9 | 10 | 11 |
| Water | 12 | 13 | 14 | 15 |
Modeling
- Initial and final state rasters are categorical one-band rasters, therefore a change map is categorical one-band raster too.
- Factor rasters are ordinal or continuous rasters (one-band or multiband), but not categoraical.
- Dummy coding for categoracal variables.
- Normalization for continuous and ordered variables.
Dummy coding
| Dummy 1 | Dummy 2 | Dummy 3 | |
| Agriculture | 0 | 0 | 1 |
| Forest | 0 | 1 | 0 |
| Urban | 1 | 0 | 0 |
| Water | 0 | 0 | 0 |
Normalization
where X is a variable, is normalized variable, is mean of X and is standard deviation of X.
- Initial preprocessing of the data (dummy coding and normalization).
- Sampling.
- Training.
MOLUSCE uses multilayer percepron with numpy.tanh sigmoid function. Therefore target variables (the change map categories) should be scaled to (-1, 1) interval during dummy coding instead (0, 1). A user can set arbitrary number of hidden layers (one or more) and arbitrary numbers (one or more) of neurons in the layers.
The created net has
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle (C-1)(2N+1)^2 + B(2N+1)^2} input neurons;
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle M} output neurons (it depends on samplig mode);
Where C is the count of land use categories, N is the neighborhood size specified by the user, B is the summary band count of factor rasters (for example if two factors are user one-band and three-band, then B=4). M usually is a count of uniques categories in the change map (Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle C^2} ). But the count of output neurons can be less then M, it depends on the sampling mode. If mode "Random" is used, some small classes could be omitted during sampling procedure.
Training set is divided in two parts learning set (80% of samples by defaults) and validation set (20% of samples).
- Graph of the average square errors. The errors (mean of all E on learning set and validation set) are calculated on learning and validation sets after every epoch and plotted on the graph.
- Min validation overall error. It is average square error E that is achieved on all validation set (mean of all E on validation set). This is the best currently achieved result. The weights of the net are stored and after training the best weights will be returned as the best net.
- Delta overall accuracy. It is the difference between min validation error and current validation error.
- Current validation kappa. It is the kappa statistic achieved on the validation set.
Logistic regression
- Sampling.
- Training.
The created model has Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle M( (C-1)(2N+1)^2 + B(2N+1)^2 + 1)} coefficients, but only Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle (M-1)( (C-1)(2N+1)^2 + B(2N+1)^2 )} are independent. As before (see perceptron discussion), C is the count of land use categories, N is neighborhood size specified by the user, B is summary band count of factor rasters (for example if two factors are user one-band and three-band, then B=4). M usually is count of uniques categories in the change map (Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle C^2} ). M depends on the sampling mode also.
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_0} is an intercept;
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1, b_2, b_3} are the coefficients of dummy variables of current landuse state (categories of the raster are coded as: 1 = (0, 0, 1); 2 = (0, 1, 0); 3 = (1, 0, 0); 4 = (0, 0, 0), see Sampler discussion);
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_4} is the coefficient of factor pixel (0-neighborhood).
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1, b_2, b_3} are the coefficients of dummy variables of current landuse state;
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_4} is the coefficient of the first factor (0-neighborhood).
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_5} is the coefficient of the second factor (0-neighborhood).
- coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{27}} are the coefficients of dummy variables of current landuse state: (Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1} , ..., Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_3} are dummy variables for the upper-left corner of 3x3 neighborhood window);
- coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{28}} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{36}} are the coefficients of the first raster pixels (1-neighborhood uses 9 pixels or 3x3 window);
- coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{37}} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{45}} are the coefficients of the second raster pixels.
Weight of evidence
Weight of evidence method was developed to process binary maps, but the method was later modified in order to enable it to handle multiple categories of variables. If user uses rasters with continues values, hi/she has to transform the rasters into categorical variables. MOLUSCE implementation uses the last one modification. To handle continues factors user must to split raster values into several categories (range binning). The GUI has a form that allows to perform transformation into categorical variables. A compromise is needed here: if the user set up too many binning values, then a small amount of pixels falls into a category and too poor accuracy of statistical calculations; in contrary if the user set up a little of binning, too few of weights are formed, that leads to poor accuracy again.
The GUI displays not all of used rasters in the binning form: if a raster is supposed as category raster, it doesn't need transformation and it doesn't appear in the form. Currently a simple procedure is used to rate rasters as categorical or continues: if a raster has more then MAX_CAT (=100) unique values, then the raster is supposed as continues, otherwise the raster is supposed as categorical.
The WoE fitting procedure starts after the transformation continue -> categorical. The change map is divided into series of binary maps (one map per a transition class), then the set of weights are estimated for every binary map.
Multi criteria evaluation
The goal of the method is predicting a transition class coded in the change map. Factor rasters are input data, places where a transition occurs are target values. MCE takes pairwaise comparison matrix of factors and calculates weights of every factor. This means, that a user must specify the comparison matrix for every transition class. But count of transition classes increases as Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle O(n^2)} , where n is count of landuse categories (for example if n=4, we have 16 transition classes). To specify all comparison matrices for all transitions is too long and bore, that's why the MCE model predicts one transition class only.
The method needs normalization of factor rasters: this implementation uses a linear combination of factors, therefore they should be transformed to Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle [0, 1]} . The module uses the next transformation:
where X is normalized raster value, x is initial raster value, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle x_{min}} is the min value of the raster, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle x_{max}} is the max value of the raster.
Simulation
- Initial state raster;
- Factor rasters;
- Model.
- Simulator takes transition probabilities from the transition matrix and calculates count of pixels that has to be changed (for every transition class);
- Simulator calls a model, pass to it initial state raster and factor rasters;
- The model scans pixels of the rasters (and its neighbors if the model uses neigborhood) and calculates transition potentials of every transition class;
- Simulator constructs a 'certancy' raster: the pixel of the raster are the difference between two most large potentials of correspondent pixels of transition potential rasters. As result the raster contains the model confidence: the bigger is difference, the bigger is confidence;
- Simulator constructs a raster of the most probable transitions: the pixels of the raster are the transition class with the biggest potential of transition. This raster is an auxiliary raster used during the next stage;
- For every transition class Simulator searches in the raster of the most probable transitions a needed count of pixels with the greatest confidence and changes the category of the pixels;
- Rasters of transition potential (scaled to percents) that are output from the models;
- Raster of the difference between the two most large potentials or 'certancy';
- Result of simulation.
Validation
- Kappa statistics;
- Error budget validation;
- Error map validation.
Kappa
- Kappa:
Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle K = \frac{P(A)-P(E)}{1-P(E)}} - Kappa location:
Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle K_{loc} = \frac{P(A) - P(E)}{P_{max}-P(E)}} - Kappa histogram:
Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle K_{h} = \frac{P_{max} - P(E)}{1-P(E)}}
where Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle P(A) = \sum_{i=1}^c p_{ii}} , Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle P(E) = \sum_{i=1}^c p_{iT}p_{Ti}} , and Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle p_{ij}} is the 'i,j'-th cell of contingency table, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle p_{iT}} is the sum of all cells in i-th row, Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle p_{Tj}} is the sum of all cells in j-th column/
Error budget
- No location information, no quantity information;
- No location information, medium quantity information;
- Medium location information, medium quantity information;
- Perfect location information, medium quantity information;
- Perfect location information, perfect quantity information.
Error map
MOLUSCE produces map of errors. This map contains information about false predictions in simulated raster. Simulated rasters stores all land use changes
Special topics
Memory Usage
Sampler uses approximately Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle N * (8 * b * c * w + 3)} bytes of memory
