- Utility modules
- Algorithmic modules:
- Area Analysis - provides procedures of change searching, making change maps
Utility modules
Data Provider
Sampler
Sampler works with single pixels and a neighborhood of pixels. This is means that a user can take into account a set of pixels around current pixel. The implementation of the algorithm uses square neighborhood. For example if the user set up 1-size neighborhood then sampling procedure reads the current pixel and all pixels located immediate vicinity (3x3 window size). If the user set up 2-size neighborhood then sampling procedure reads the current pixel and all pixels located in 5x5 window size and so on. Every neighborhood is stored as vector (9 elements, 25 elements and so on). That sampling is performed for every input raster (initial state raster and factors).
Therefore, a sample contains:
- coordinates of the pixel,
- state pixel vector is the neighborhood that is read from 1-band raster, this raster contains initial states (categories). The raster is divided into set of dummy variables before sampling (see below).
- factor pixel vectors are the neighborhoods extracted from factor rasters (they can be multiband).
- "All". This mode allows store all pixels of the input and output rasters. The mode of sampling needs big amount of RAM and CPU time if input rasters are big.
Cross Tabulation
| Category 1 | Count of unchanged pixels of Category 1 | Count of transition Category 1 - > Category 2 | ... | Count of transition Category 1 - > Category N |
| Category 2 | Count of transition Category 2 - > Category 1 | Count of unchanged pixels of Category 2 | ... | Count of transition Category 2 - > Category N |
| Category N | Count of transition Category N - > Category 1 | Count of transition Category N - > Category 2 | ... | Count of unchanged pixels of Category N |
Algorithmic modules
Area Analysis
| Category 2 | N | N + 1 | ... | 2N -1 |
| Category N | (N-1)*N | (N-1)*N + 1 | ... | N*N -1 |
| Agriculture | Forest | Urban | Water | |
| Agriculture | 0 | 1 | 2 | 3 |
| Forest | 4 | 5 | 6 | 7 |
| Urban | 8 | 9 | 10 | 11 |
| Water | 12 | 13 | 14 | 15 |
Modeling
- Initial and final state rasters are categorical one-band rasters, therefore a change map is categorical one-band raster too.
- Factor rasters are ordinal or continuous rasters (one-band or multiband), but not categoraical.
- Dummy coding for categoracal variables.
- Normalization for continuous and ordered variables.
Dummy coding
| Dummy 1 | Dummy 2 | Dummy 3 | |
| Agriculture | 0 | 0 | 1 |
| Forest | 0 | 1 | 0 |
| Urban | 1 | 0 | 0 |
| Water | 0 | 0 | 0 |
Normalization
where X is a variable, is normalized variable, is mean of X and is standard deviation of X.
- Initial preprocessing of the data (dummy coding and normalization).
- Sampling.
- Training.
MOLUSCE uses multilayer percepron with numpy.tanh sigmoid function. Therefore target variables (the change map categories) should be scaled to (-1, 1) interval during dummy coding instead (0, 1). A user can set arbitrary number of hidden layers (one or more) and arbitrary numbers (one or more) of neurons in the layers.
The created net has
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle (C-1)(2N+1)^2 + B(2N+1)^2} input neurons;
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle M} output neurons (it depends on samplig mode);
Where C is the count of land use categories, N is the neighborhood size specified by the user, B is the summary band count of factor rasters (for example if two factors are user one-band and three-band, then B=4). M usually is a count of uniques categories in the change map (Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle C^2} ). But the count of output neurons can be less then M, it depends on the sampling mode. If mode "Random" is used, some small classes could be omitted during sampling procedure.
Training set is divided in two parts learning set (80% of samples by defaults) and validation set (20% of samples).
- Graph of the average square errors. The errors (mean of all E on learning set and validation set) are calculated on learning and validation sets after every epoch and plotted on the graph.
- Min validation overall error. It is average square error E that is achieved on all validation set (mean of all E on validation set). This is the best currently achieved result. The weights of the net are stored and after training the best weights will be returned as the best net.
- Delta overall accuracy. It is the difference between min validation error and current validation error.
- Current validation kappa. It is the kappa statistic achieved on the validation set.
Logistic regression
- Sampling.
- Training.
The created model has Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle M( (C-1)(2N+1)^2 + B(2N+1)^2 + 1)} coefficients, but only Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle (M-1)( (C-1)(2N+1)^2 + B(2N+1)^2 )} are independent. As before (see perceptron discussion), C is the count of land use categories, N is neighborhood size specified by the user, B is summary band count of factor rasters (for example if two factors are user one-band and three-band, then B=4). M usually is count of uniques categories in the change map (Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle C^2} ). M depends on the sampling mode also.
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_0} is an intercept;
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1, b_2, b_3} are the coefficients of dummy variables of current landuse state (categories of the raster are coded as: 1 = (0, 0, 1); 2 = (0, 1, 0); 3 = (1, 0, 0); 4 = (0, 0, 0), see Sampler discussion);
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_4} is the coefficient of factor pixel (0-neighborhood).
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1, b_2, b_3} are the coefficients of dummy variables of current landuse state;
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_4} is the coefficient of the first factor (0-neighborhood).
- Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_5} is the coefficient of the second factor (0-neighborhood).
- coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{27}} are the coefficients of dummy variables of current landuse state: (Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_1} , ..., Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_3} are dummy variables for the upper-left corner of 3x3 neighborhood window);
- coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{28}} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{36}} are the coefficients of the first raster pixels (1-neighborhood uses 9 pixels or 3x3 window);
- coefficients from Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{37}} thru Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle b_{45}} are the coefficients of the second raster pixels.
Weight of evidence
Weight of evidence method was developed to process binary maps, but the method was later modified in order to enable it to handle multiple categories of variables. If user uses rasters with continues values, hi/she has to transform the rasters into categorical variables. MOLUSCE implementation uses the last one modification. To handle continues factors user must to split raster values into several categories (range binning). The GUI has a form that allows to perform transformation into categorical variables. A compromise is needed here: if the user set up too many binning values, then a small amount of pixels falls into a category and too poor accuracy of statistical calculations; in contrary if the user set up a little of binning, too few of weights are formed, that leads to poor accuracy again.
The GUI displays not all of used rasters in the binning form: if a raster is supposed as category raster, it doesn't need transformation and it doesn't appear in the form. Currently a simple procedure is used to rate rasters as categorical or continues: if a raster has more then MAX_CAT (=100) unique values, then the raster is supposed as continues, otherwise the raster is supposed as categorical.
The WoE fitting procedure starts after the transformation continue -> categorical. The change map is divided into series of binary maps (one map per a transition class), then the set of weights are estimated for every binary map.
Multi criteria evaluation
MCE model needs pairwaise comparison matrix for a transition class
Simulation
Рассказать, как работает симулятор, если модель поддерживает анализ окрестностей. Рассказать, что будет, если модель не работает с окрестностями.
Рассказать, как выбирается количество точек для переходов и каким образом места этих переходы выбираются.
Рассказать, что будет, если задать несколько итераций симуляции.
Validation
Формулы для расчетов валидации.
Special topics
Memory Usage
Sampler uses approximately Невозможно разобрать выражение (SVG (MathML можно включить с помощью плагина для браузера): Недопустимый ответ («Math extension cannot connect to Restbase.») от сервера «https://wikimedia.org/api/rest_v1/»:): {\displaystyle N * (8 * b * c * w + 3)} bytes of memory
