- Utility modules
- Algorithmic modules:
- Area Analysis - provides procedures of change searching, making change maps
Utility modules
Data Provider
Sampler
A sample contains:
- coordinates of pixel,
- state is data that is read from 1-band raster, this raster contains initial states (categories). Categories are splitted into set of dummy variables.
- factors is list of rasters (they can be multiband) that explain transition between states (categories).
- "All". This mode allows store all pixels of the input and output rasters.
Algorithmic modules
Area Analysis
The main purpose of area analysis module is change map calculation. The module uses the next scheme of transition encoding.
| Category 1 | N | N + 1 | ... | 2N -1 |
| Category 1 | (N-1)*N | (N-1)*N + 1 | ... | N*N -1 |
