- Utility modules
- Algorithmic modules:
- Area Analysis - provides procedures of change searching, making change maps
Utility modules
Data Provider
- Creation and storing rasters
- reading data from file. If the file contains no-data values, that pixels will be stored as masked pixels. An user can specify additional list of no-data values. The initialization procedure uses gdal utilities and can read all data types that are supported by gdal.
- creating new raster
- saving data. A raster can be saved into a file, the method uses gdal utilities.
- Access to the data and data manipulation
- Read raster band from internal storage.
- setBand method is the opposite for getBand. It allows to replace a band by new array of pixels, for example
r.setBand(band, bandNumber)
- getBandsCount method gives information about number of bands stored in the raster variable:
count = r.getBandsCount()
- getBandGradation and getBandStat methods provides statistics of raster's bands (min/max values, standard deviation and list of unique values stored in the band).
- normalize and denormalize methods are used by some algorithmic procedures. For example, Multi-layer perceptron or Logistic Regression predictors usually are better if input data are normalized. To normalize the data the training procedure must use some statistic information (see for example getBandStat).
- getGeodata method reads geometry and geography related information from the raster variable. Raster variable stores information about pixel sizes (dx and dy), data origin, projection of the raster data and so on. All of such information are encapsulated into special object - geodata. User can read the information via the method:
geodata = r.getGeodata()
- setGeoData method is the opposite for getGeodata method. It can be used, for example, during creating a new raster variable.
- Comparing geodata objects
- geoDataMatch performs comparing of geodata (raster sizes, projections and geo transform objects) of one raster and another geodata. The method is useful for most of raster operations between two different rasters. For example module can perform arithmetic operation on two raster if rasters have a equal pixel size, origin and projection.
- geoTransformMatch performs comparing of two raster's geo transform objects.
Sampler
A sample contains:
- coordinates of pixel,
- state is data that is read from 1-band raster, this raster contains initial states (categories). Categories are splitted into set of dummy variables.
- factors is list of rasters (they can be multiband) that explain transition between states (categories).
Samples are stored as named tuples:
np.array(Count_Of_Samples,
dtype=[
('coords', float, 2),
('state', float, Count_Of_Dummy_Vars*Moving_Win_Size),
('factors', float, Moving_Win_Size*Summary_Band_Count),
('output', float, 1)
But this structure is internal and user should use special methods to create samples and to take the stored data. The module has the next functions for data manipulation:
- setTrainingData method takes several arguments (input and output rasters, mode of sampling, count of desired samples etc.) and performs sampling. One of the most important parameters is mode, it can be one of list:
- "All". This mode allows store all pixels of the input and output rasters.
- getData function returns stored array of samples.
- saveSamples method allow to save samples as point *shp file. Every sample will be saved as a point.
Algorithmic modules
Area Analysis
The main purpose of area analysis module is change map calculation. The main methods of the module are makeChangeMap and getChangeMap. The first of them performs encoding and creating of change map. The module uses the next scheme of transition encoding:
It can be represented as
Code_Of_Iinitial_Class * Count_Of_Classes + code_Of_Final_Class
