  • MOLUSCE is a QGIS plugin for Land Use Change Evaluation. MOLUSCE stands for Methods Of Land Use Chande Evaluation. Briefly, tThe plugin performs the following process:
  1. Takes raster of land use categories for the past time, raster of land use categories for the present time and rasters of explanatory variables or factors.
  2. Trains a model that predicts land use changes.
  3. Predicts future land use changes via model, current state of land use and current factors.
  • State raster is one-band raster that contains landuse categories encoded in the raster's pixels.
  • Input state raster is one-band raster that contains landuse categories of the past. It is an input for used model.
  • Factor rasters are rasters of explanatory variables. The rasters can be one-band or multy-band. These are inputs for used model.
  • Output state raster is one-band raster that contains landuse categories of the present. It is the desired result of prediction for model (a user trains the model to predict (input raster, factors) -> output raster).
  • Transition class or simple 'transition' is a information about land use change. Every change (for example forest -> non-forest) can be viewed as a transition of land use categories (encoded as pixels) from Input state raster to Output state raster.
  • Change map is a one-band raster that stores information about transitions. Category values of change map are one-to-one mapped to transition classes.
  • Utility modules
  • Algorithmic modules:
    • Area Analysis - provides procedures of change searching, making change maps
Utility modules
Data Provider
Sampler
Sampler works with single pixels and a neighborhood of pixels. This is means that a user can take into account a set of pixels around current pixel. The implementation of the algorithm uses square neighborhood. For example if the user set up 1-size neighborhood then sampling procedure reads the current pixel and all pixels located immediate vicinity (3x3 window size). If the user set up 2-size neighborhood then sampling procedure reads the current pixel and all pixels located in 5x5 window size and so on. Every neighborhood is stored as vector (9 elements, 25 elements and so on). That sampling is performed for every input raster (initial state raster and factors).
Therefore, a sample contains:
  • coordinates of the pixel,
  • "All". This mode allows store all pixels of the input and output rasters. The mode of sampling needs big amount of RAM and CPU time if input rasters are big.
  • "Random". This mode allows store random selected samples: if output raster (target raster) has N pixels, then the every pixel has probability of selection 1/N.
  • "Stratified". This mode allows undersampling of major categories and/or oversampling of minor categories. If C is desired count of samples and K is number of output categories, then the sampling procedure select K random groups of pixels of equal size C/K. Every group will contain pixels of one certain category.
Cross Tabulation
Algorithmic modules
Area Analysis
Category 1 0 1 ... N -1
Category 2 N N + 1 ... 2N -1
Agriculture 0 1 2 3
Forest 4 5 6 7
Urban 8 9 10 11
Water 12 13 14 15
Modeling
  • Factor rasters are ordinal or continuous rasters (one-band or multiband), but not categoraical.
  • Dummy coding for categoracal variables.
Dummy coding
Dummy 1 Dummy 2 Dummy 3
Agriculture 0 0 1
Forest 0 1 0
Urban 1 0 0
Water 0 0 0
Normalization
where X is a variable, is normalized variable, is mean of X and is standard deviation of X.
  2. Sampling.
  3. Training.
MOLUSCE uses multilayer percepron with numpy.tanh sigmoid function. Therefore target variables (the change map categories) should be scaled to (-1, 1) interval during dummy coding instead (0, 1). A user can set arbitrary number of hidden layers (one or more) and arbitrary numbers (one or more) of neurons in the layers.
The created net has
  • input neurons;
  • output neurons (it depends on samplig mode);
Where C is the count of land use categories, N is the neighborhood size specified by the user, B is the summary band count of factor rasters (for example if two factors are user one-band and three-band, then B=4). M usually is a count of uniques categories in the change map (). But the count of output neurons can be less then M, it depends on the sampling mode. If mode "Random" is used, some small classes could be omitted during sampling procedure.
Training set is divided in two parts learning set (80% of samples by defaults) and validation set (20% of samples).
where E is a sample error, is the target value of a output neuron for given sample, is the real output value of the neuron, d is the count of output neurons.
  • Min validation overall error. It is average square error E that is achieved on all validation set (mean of all E on validation set). This is the best currently achieved result. The weights of the net are stored and after training the best weights will be returned as the best net.
Logistic regression
  2. Sampling.
  3. Training.
The created model has coefficients, but only are independent. As before (see perceptron discussion), C is the count of land use categories, N is neighborhood size specified by the user, B is summary band count of factor rasters (for example if two factors are user one-band and three-band, then B=4). M usually is count of uniques categories in the change map (). M depends on the sampling mode also.
  • is an intercept;
  • are the coefficients of dummy variables of current landuse state (categories of the raster are coded as: 1 = (0, 0, 1); 2 = (0, 1, 0); 3 = (1, 0, 0); 4 = (0, 0, 0), see Sampler discussion);
  • is the coefficient of factor pixel (0-neighborhood).
  • is an intercept;
  • are the coefficients of dummy variables of current landuse state;
  • is the coefficient of the first factor (0-neighborhood).
  • is the coefficient of the second factor (0-neighborhood).
  • is an intercept;
  • coefficients from thru are the coefficients of dummy variables of current landuse state: (, ..., are dummy variables for the upper-left corner of 3x3 neighborhood window);
  • coefficients from thru are the coefficients of the first raster pixels (1-neighborhood uses 9 pixels or 3x3 window);
  • coefficients from thru are the coefficients of the second raster pixels.
Weight of evidence
Weight of evidence method was developed to process binary maps, but the method was later modified in order to enable it to handle multiple categories of variables. If user uses rasters with continues values, hi/she has to transform the rasters into categorical variables. MOLUSCE implementation uses the last one modification. To handle continues factors user must to split raster values into several categories (range binning). The GUI has a form that allows to perform transformation into categorical variables. A compromise is needed here: if the user set up too many binning values, then a small amount of pixels falls into a category and too poor accuracy of statistical calculations; in contrary if the user set up a little of binning, too few of weights are formed, that leads to poor accuracy again.
The GUI displays not all of used rasters in the binning form: if a raster is supposed as category raster, it doesn't need transformation and it doesn't appear in the form. Currently a simple procedure is used to rate rasters as categorical or continues: if a raster has more then MAX_CAT (=100) unique values, then the raster is supposed as continues, otherwise the raster is supposed as categorical.
The WoE fitting procedure starts after the transformation continue -> categorical. The change map is divided into series of binary maps (one map per a transition class), then the set of weights are estimated for every binary map.
Multi criteria evaluation
The goal of the method is predicting a transition class coded in the change map. Factor rasters are input data, places where a transition occurs are target values. MCE takes pairwaise comparison matrix of factors and calculates weights of every factor. This means, that a user must specify the comparison matrix for every transition class. But count of transition classes increases as , where n is count of landuse categories (for example if n=4, we have 16 transition classes). To specify all comparison matrices for all transitions is too long and bore, that's why the MCE model predicts one transition class only.
The method needs normalization of factor rasters: this implementation uses a linear combination of factors, therefore they should be transformed to . The module uses the next transformation:
where X is normalized raster value, x is initial raster value, is the min value of the raster, is the max value of the raster.
Simulation
  • Init state raster;
  • Factor rasters;
  • Model.
Init state raster contains information about current land use categories, factor rasters contain information about explanatory variables. Model is a predictor that calculates transition potentials in the condition of the factors and current land use. So module doesn't uses implicit transition rules, it uses transition potentials generated by the models. The neighborhood effect is achieved if a model uses neighborhood during training, for example logistic regression has a coefficient for every neighbor and the coefficient affects the transition potential. If model doesn't uses neighborhood, Simulator takes into account only general patterns.
Рассказать, как работает симулятор, если модель поддерживает анализ окрестностей. Рассказать, что будет, если модель не работает с окрестностями.
Рассказать, как выбирается количество точек для переходов и каким образом места этих переходы выбираются.
Рассказать, что будет, если задать несколько итераций симуляции.
Validation
Формулы для расчетов валидации.
Special topics
Memory Usage
Sampler uses approximately bytes of memory
