  • MOLUSCE is a QGIS plugin for Land Use Change Evaluation. MOLUSCE stands for Methods Of Land Use Chande Evaluation. Briefly, tThe plugin performs the following process:
  1. Takes raster of land use categories for the past time, raster of land use categories for the present time and rasters of explanatory variables or factors.
  2. Trains a model that predicts land use changes.
  3. Predicts future land use changes via model, current state of land use and current factors.
  • State raster is one-band raster that contains landuse categories encoded in the raster's pixels.
  • Input state raster is one-band raster that contains landuse categories of the past. It is an input for used model.
  • Factor rasters are rasters of explanatory variables. The rasters can be one-band or multy-band. These are inputs for used model.
  • Output state raster is one-band raster that contains landuse categories of the present. It is the desired result of prediction for model (a user trains the model to predict (input raster, factors) -> output raster).
  • Transition is a information about land use change. Every change (for example forest -> non-forest) can be viewed as a transition of land use categories (encoded as pixels) from Input state raster to Output state raster.
  • Change map is a one-band raster that stores information about transitions.
  • Utility modules
  • Algorithmic modules:
    • Area Analysis - provides procedures of change searching, making change maps
Utility modules
Data Provider
Sampler
A sample contains:
  • coordinates of pixel,
    • state is data that is read from 1-band raster, this raster contains initial states (categories). Categories are splitted into set of dummy variables.
    • factors is list of rasters (they can be multiband) that explain transition between states (categories).
  • "All". This mode allows store all pixels of the input and output rasters. The mode of sampling needs big amount of RAM and CPU time if input rasters are big.
  • "Random". This mode allows store random selected samples: if output raster (target raster) has N pixels, then the every pixel has probability of selection 1/N.
  • "Stratified". This mode allows undersampling of major categories and/or oversampling of minor categories. If C is desired count of samples and K is number of output categories, then the sampling procedure select K random groups of pixels of equal size C/K. Every group will contain pixels of one certain category.
Cross Tabulation
Algorithmic modules
Area Analysis
Category 1 0 1 ... N -1
Category 2 N N + 1 ... 2N -1
Agriculture 0 1 2 3
Forest 4 5 6 7
Urban 8 9 10 11
Water 12 13 14 15
Modeling
  • Factor rasters are ordinal or continuous rasters (one-band or multiband), but not categoraical.
  • Dummy coding for categoracal variables.
Dummy coding
Dummy 1 Dummy 2 Dummy 3
Agriculture 0 0 1
Forest 0 1 0
Urban 1 0 0
Water 0 0 0
Normalization
where X is a variable, is normalized variable, is mean of X and is standard deviation of X.
The plugin uses classic realization of Multilayer perceptron. The input data is a collection of pixels of initial state raster and factor rasters. The target output data is the change map. The plugin performs the next actions:
  2. Sampling.
  3. Training.
The initial stages are described in the previous section, this subsection discussed the training procedure.
Logistic regression
Weight of evidence
Multi criteria evaluation
Simulation
Validation
Special topics
Memory Usage
Sampler uses approximately bytes of memory
